Starting issues
Old Oct 26, 2015 | 09:39 AM
Anok's Avatar
Default Starting issues
Hello all, I have a 2004 honda accord ex 4cyl. Lately sometimes when i turn the key i will hear a strange noise coming from somewhere in the steering column or underneath it somewhere, it will make this noise and not start for a few times and twice it did not make any noise and not start at all, i dont think its the starter and the ignition was replaced about a year ago after my car was stolen. Is there a solenoid somewhere around inside the steering box or down by the fuses that could cause this? Or something else, thanks for your help
Old Oct 26, 2015 | 09:47 AM
There is a starter-cut relay in the under-dash fuse/relay box. Possibly this is noise you are hearing.
Old Oct 26, 2015 | 10:03 AM
Anok's Avatar
Is it a replaceable relay? autozone and advanced have no listing for a starter-cut relay. its like a buzzing sound
Old Oct 26, 2015 | 10:23 AM
Yes replaceable, that is why relay is in the fuse/relay box. Check cover lid for guidance on which relay. Pull relay and go to AZ to match or puchase OEM relay from Honda.
Old Oct 27, 2015 | 05:25 PM
holmesnmanny's Avatar
If you have an aftermarket alarm(especially viper which are notorious for this) your starter kill function could be malfunctioning. I had this happen myself and it normally happened after driving the car for a bit. Wired out the ignition kill and no issues since.
Old Oct 28, 2015 | 10:20 AM
Anok's Avatar
I ended up buying a ignition starter switch after searching on youtube about the "buzzing" sound when trying to turn the key. Someone shared a video on it and he tried the relay/fuse 1st=made no difference, than installed the starter switch and it cured the problem, he noted that the 2000+ models are know for this issue. Ill install mine this Saturday and post here whether it fixed it or not.
Old Nov 3, 2015 | 01:35 PM
Did replacing starter switch assy fix the problem?
Old Nov 4, 2015 | 01:06 PM
Anok's Avatar
Yes it did, works like a charm!
Old Nov 5, 2015 | 09:34 AM
Thanks for followup!
Slowaccord
Aug 28, 2007 08:38 AM
sir_nasty
Feb 7, 2007 04:19 PM
MRMASON
Oct 3, 2006 07:09 PM
brad6841
May 22, 2006 09:38 AM
brad6841
Apr 13, 2006 06:20 AM
