starting problems
Old Apr 26, 2022 | 06:16 PM
robc's Avatar
Angry starting problems
My 2013 accord has failed to start 3 times in the last 16 months, the engine will crank but not turn over as if the battery were dying. i let it sit then come back 15 minutes(ish) and it starts normal. Battery is new, thoughts?
Old Apr 26, 2022 | 06:32 PM
Terminology for an engine not starting is confusing and can lead down the wrong diagnostic path. Cranking means you turn the key to start the engine and the starter motor spins the engine. When your engine is running on its own, is when the engine starts. So do you have a crank/no-start or a no-crank/no-start?
Old Apr 27, 2022 | 10:29 AM
robc's Avatar
hi , initially it will crank and not start, but after a couple of attempts is goes down to no crank no start. come back 20 or so minutes later and starts right up
Old Apr 27, 2022 | 12:22 PM
rockhoundrob's Avatar
I would say you have a bad battery, or you have bad connections to the battery.
2nd choice would be bad ground.
Try removing both connections to the battery and clean the posts and the connections on the battery cable.
Old Apr 27, 2022 | 07:52 PM
Bad battery is unlikely, because the battery wouldn't recharge itself. 3 times in the last 16 months is an extremely intermittent problem. I'd start with cleaning connections. Disconnect the battery and clean all ends of both battery cables. Clean the bolt and eyelets with a wire brush or sandpaper, the battery posts as well to ensure a good connection.
h11keu
Dec 25, 2016 12:43 PM
DaveG
May 19, 2015 09:55 AM
JimB4
Nov 19, 2011 12:10 PM
swano586
Nov 18, 2009 09:02 PM
hansw3
Dec 21, 2008 04:09 PM
