starting problems when hot
Old Dec 15, 2007 | 04:51 AM
opaitsalex's Avatar
Default RE: starting problems when hot
its a auto
and as far as i know da cables are fine
im not sure about the starter
but idle is fine it works great on cold start
and hot start to when the engine doesnt stall
[IMG]local://upfiles/14174/199891499D844DC8A867988809E59635.jpg[/IMG]
Old Dec 15, 2007 | 02:36 PM
honda97valdeez's Avatar
Crazy car.
Old Dec 15, 2007 | 02:50 PM
opaitsalex's Avatar
lol
so what do u guys think i should do now?
Old Dec 15, 2007 | 02:56 PM
sir_nasty's Avatar
did you check the fuel pressure?
Old Dec 15, 2007 | 03:37 PM
opaitsalex's Avatar
no not yet didnt have the chance yet
but i was thinking how can it be fuel pressure if this problem is only at start up and not when the engine is running
Old Dec 15, 2007 | 03:55 PM
Here is something that is simple to try when the car is having the starting problem.
Turn the key to the II position and allow all of the clicks to happen, but do not start the car. Try to listen for the fuel pump to whirl for a few seconds. Turn the key off. Repeat turning the key to II a couple of times. This should allow the fuel pressure to build up in the rail. If the car starts proplerly, then you can pressure test the fuel system.
Are your maintenance items on the car been kept up? Like the spark plugs, plug wires, air filter, etc... You might want to stop by Autozone and have them test the battery/alternator to make sure they are working properly.
Old Dec 15, 2007 | 04:02 PM
  #17
sir_nasty's Avatar
this is a random shot in the dark so you can try it if you like but I'm just guessing wildely..... There have been a number of issues that can be caused by the FITV and coolant levels, check your coolant and make sure it's full, then bleed the system to make certain there is no air in it.
What kind of spark plugs are you using?
Old Dec 15, 2007 | 06:13 PM
  #18
opaitsalex's Avatar
well i bought the car in september
and the previous owner told me he just changes pluges wires and air filter not to long ago im not sure wat the plugs are i think its ac delco
Old Dec 15, 2007 | 06:15 PM
  #19
opaitsalex's Avatar
by the way thanx alot for all of your help guys
Old Dec 16, 2007 | 02:28 AM
  #20
I would put NGKs in there, since they are OEM. Most techs on here suggest using them over AC Delco plugs.
