It starts when it wants to
Old Apr 19, 2010 | 02:48 PM
rwyatt80's Avatar
Default It starts when it wants to
Ok....a few months ago, while at the gas station, I tried to start my car. Everything came on (dash lit up, radio came on) but the car wouldnt start. There was no clicking when i turned the key, just silence. I waited a few minutes, started it again, it started right up.
Today, same thing. I had the starter replaced a few years ago. Could it be that the starter is going bad again....or could it be something else
Any help is appreciated
96 Accord Lx 4cyl
Old Apr 19, 2010 | 02:54 PM
Auto trans?
Check the shift interlock.
Manual trans?
Check the clutch switch.
Either way, it might be flaky connections (corrosion, loose, ??) at the battery cables - both ends.
Caveman test for the starter...
While someone holds the key at "START" position, hit the starter with a broom handle. If that makes it run, it's a bad starter.
Old Apr 19, 2010 | 08:25 PM
rwyatt80's Avatar
shift interlock???????
Where might that be located??
Old Apr 19, 2010 | 08:36 PM
g22cd5's Avatar
Supper Moderator
It’s a solenoid that is connected to the shifter. You have to pop the console around the shifter. This went bad on my cb and I just removed it totally. With the key in the on poss. can you move the shifter out of park? If not then it's the shifter interlock solenoid. Easy fix personally I'd just remove it if you can. I'm not sure if you have to have it on the newer accords but on the older ones you can just delete it and be done with it.
Old Apr 19, 2010 | 09:10 PM
rwyatt80's Avatar
I will try that in the morning. If it is the solenoid, would just removing it do any damage?? Or should I replace the part???
Old Apr 20, 2010 | 06:54 AM
G22, you're describing the interlock that prevents you from shifting out of PARK unless you're standing on the brake.
There's another interlock in the other direction. This one prevents you from starting the engine when it's in gear. It's only supposed to allow the starter to run when the transmission is in PARK or NEUTRAL. If the lamps in the cluster don't accurately represent what gear it's in, then you should check that out.
Old Apr 20, 2010 | 09:36 AM
deserthonda's Avatar
go to the DIY section,, there is a write up on how to diagnose your issue
Old Apr 21, 2010 | 04:58 AM
rwyatt80's Avatar
The culprit seems to be the battery. I will be checking the shift interlock anyway...Thanks so much !!
Old Apr 22, 2010 | 12:37 PM
if you found the cause ( battery ) why would you chk the shift interlock ?? if car starts ,it means that it is working ok..
Old Apr 23, 2010 | 04:19 AM
rwyatt80's Avatar
ok.
rockingvikes2007
Oct 13, 2008 03:46 PM
Hobbin
Jun 23, 2008 11:07 AM
HondaRacer4Vtec
Dec 4, 2007 07:02 PM
xpieceofcralpx
Sep 24, 2007 06:08 PM
4drwithspeed
May 20, 2005 05:18 PM
