Steering wheel shakes...
Old Jun 12, 2005 | 02:58 PM
Guest
Default Steering wheel shakes...
Hi again... I've got a '94 Accord EX... when I get above 50 MPH my steering wheel shakes and the car pulls a little to the right.. Is this an alignment problem, or brake/bearing problem??
I have replaced both bearings, CV joints, rotors, brakes, and upgraded up to 16" wheels. I have not yet got an alignment...
Also posted in Suspention forum..
Thanks.
Old Jun 12, 2005 | 03:25 PM
dachoka
Default RE: Steering wheel shakes...
The problem is in your tires. Have them balanced, if they were already balanced, have them rebalanced, use weights on both sides of the wheel, if not applicable, use stick weights on the inside. Rotate your tires from left to right on the front and see if the pulling stops, if not, align the vehicle.
Let me know how it goes. Any other questions, feel free to email me.
dachoka@aeg1.net
Old Jun 13, 2005 | 12:12 AM
Alekat's Avatar
Another possibility is a bad strut. Even though the tires are balanced - wheel tramp can result at higher speeds if strut dampening is not sufficient.
Believe it or not.
Old Jun 13, 2005 | 08:40 PM
Guest
Sorry... I forgot to mention that I put brand new high performance struts on the car... sorry again
Old Jul 3, 2005 | 03:38 AM
Guest
problem fixed... got a whole new hub assembly for the passenger side.... bearings rotor and rotor hub...
DaWells84
May 6, 2012 09:57 AM
remgene
Jan 5, 2012 11:50 AM
Jcaleno
Jun 4, 2009 07:05 AM
hatingmyhonda
Jan 25, 2008 09:39 AM
Aug 22, 2007 01:57 PM
