Sticky throttle???
Old Oct 15, 2007 | 01:01 AM
Planefreak's Avatar
Default Sticky throttle???
This is more of an annoyance than an issue. My dad's car (a 2000 Honda Accord 2.3l, auto, EX sedan) has a sticky gas pedal. He's taken it to the shop because they said they'd do it cheap, but he doesn't want to take it there, so I am asking you guys. It mainly happens when it's cold, but it is noticeable at other times. Does anyone have any ideas on what to do? I know the shop cleaned something, but I'm not sure what and I don't want to take a bunch of stuff off and not be able to get it back together.
Old Oct 15, 2007 | 06:24 AM
Chiovnidca's Avatar
Default RE: Sticky throttle???
Sticking closed? Try cleaning the throttle body.
Old Oct 23, 2007 | 07:43 PM
62maxx's Avatar
Like Chio mentioned, try cleaning the throttle body. I had the same problem. It alwayshappened after the car sat for a while and "cooled down".I thought it was the throttle cables but it was not. I removed the rubber "tube" leading from the air box to the throttle body and got a flash light and looked inside. Right by the metal "flap" there was gum & varnish residue. I used some spray can"hogwash" and cleaned itwith the engine running buthad to shut the engine off and hold the flap open and wipe around the area. that did the trick.... smooth as ever....
Old Oct 23, 2007 | 11:31 PM
accord4sroy's Avatar
Yeah, we had that problem on our 99, and we got a fuel system cleaning. Deposits form after a while (especially if it had previously been driven in a decent amount of stop and go driving).
Old Oct 24, 2007 | 09:32 AM
00AccordLX5spd's Avatar
Registered User
I currently have the same problem in my 2000, but I haven't posted here cause I figured I just need to clean the TB as mentioned above. Clean the TB and maybe try some SeaFoam! Hopefully I'll get around to mine this weekend. It's annoying the crap out of me.
Al_S
Jun 26, 2010 08:17 PM
88lxaccord3152
Jul 16, 2009 08:40 AM
sir_nasty
Sep 25, 2007 08:22 PM
Smokey
Nov 30, 2006 02:12 AM
technical_sedan93
May 9, 2005 12:02 AM
