struts maybe something else?
Old Dec 10, 2007 | 01:13 AM
ckebottle's Avatar
Default struts maybe something else?
So when I was driving today I heard a creaking sound when I was driving today. I got out of the car and pushed down on the hood of car and it makes a creaking sound like when you were a kid and would jump up and down on a bed. I'm guessing struts? Another thing that makes a kinda creaking noise is when I'm turning the steering wheel. Could that be related to the struts (if that is the plm which i'm guessing it is) or is that another plm?
Old Dec 10, 2007 | 02:35 AM
ckebottle's Avatar
Default RE: struts maybe something else?
Thought I would add that it seems to make more of creaking sound from engine bay then by wheel well. I hope its the struts and not ball joints or something difficult...but i'd like some ideas before I take any action or take it in somewhere since I trust ur guys' opinions. Oh yeah, it seems to be a lot louder on one side than the other.
Old Dec 10, 2007 | 05:00 AM
BlkCurrantKord's Avatar
Check some of your bushings.
Old Dec 10, 2007 | 09:29 AM
xpieceofcralpx's Avatar
Almost A Senior Member
i had the same problem with the squeaking, and it turned out that one of my struts blew out, check ur wheel well, where the springs are at, and see if it did blow out, and see like oil build up at the bottom of it
Old Dec 10, 2007 | 10:34 AM
Since it sounds more like engine bay rather than wheels, look at some inboard stuff.
Inboard pivots of lower control arms?
Sway-bar bushings?
Bushings at front end of radius rods?
Old Dec 10, 2007 | 10:53 AM
srlance24's Avatar
I had the same problem not to long ago and it turned out to be the lower ball joints being loose and binding. Try jacking the car up, putting the key in the ignition (dont start it) and turn the wheel back and forth, if it is creaking its the ball joints. If it isn't creaking it can still be the ball joints, they just aren't making noise because there isn't a load on them.
Does your steering not return to center after you make a turn? That's a big sign its a ball joint problem.
Old Dec 10, 2007 | 01:40 PM
ckebottle's Avatar
I'll defintely do that test in a few days srlance24. Is it still safe to drive the car on the freeway?
Are the front swaybar bushings easy to find?
Old Dec 10, 2007 | 04:26 PM
Front swaybar #1 pivots in it's bushings #2.They're fairly common to make somenoise. Squirt some silicone spray in there. Very temporary, but it'll show whether that's the source of the noise.
Also try the inboard pivots for the lower control arms (#12).
Old Dec 10, 2007 | 05:01 PM
ckebottle's Avatar
Thanks for that diagram Jim!
And yes the steering wheel does return to center.
Old Dec 10, 2007 | 05:13 PM
sir_nasty's Avatar
if the silicone helps the squeek then look for some water resistant lubricant, common stuff for polyeurethane bushings since they have a tendancy to squeek as well.
