Stuck Head Bolt F22 VTEC
Old Apr 5, 2015 | 10:19 AM
yankmecrank's Avatar
Angry Stuck Head Bolt F22 VTEC
Got the engine out of the car and am now trying to remove the head so that I can inspect block and cylinder head. I got the number one loosened (just to break loose) as specified in the manual. But number two would not budge, unbelievably. The manual states install torque of 79 ft-lbs. so I wasn't expecting trouble. But this MF is stuck big time. Tried breaker bar, 1/2 in. drive impact, NADA. Actually broke the socket trying to remove. I think it spun out too so now I have the prospect of having to grind out the damn thing. Has anybody out there had so much trouble loosening head bolts on this engine?
Old Apr 5, 2015 | 11:41 AM
You are not the first one.
Are/were you using an impact socket? If not, get one for the rest of them.
Now for the one that "might" be rounded....got any pic's?
Old Apr 5, 2015 | 11:45 AM
Go to home depot/lowes, get a 8ft steel pipe that will fit over your breaker bar. Best investment I ever made. Never not been able to get a bolt loose with that.
Sure for a crank pulley bolt on a Honda 4cyl I had to jump on the 8ft pipe on the breaker bar, but it did come loose.
Old Apr 5, 2015 | 12:12 PM
^X2.....over time I have ended up with a few different lengths of pipe to fit "a job"
Old Apr 5, 2015 | 02:22 PM
Turtlehead's Avatar
I prefer using a 1/2 impact gun with a new high grade 6pt socket. Just run them out. Follow the torquing procedure properly when reinstalling.
maverick2k7
Feb 5, 2011 08:59 PM
jason5521
Nov 15, 2009 01:19 AM
AbaZ
18
Jul 16, 2008 10:23 PM
SpanishN00b
Jul 29, 2007 07:11 PM
EMEX
Mar 21, 2007 02:08 AM
