Stumbling only after temperature reached
Old Jun 24, 2008 | 08:21 PM
Alekat's Avatar
Default Stumbling only after temperature reached
1987 Accord LX carb'd 2.0L w/AT.
Runs perfect until engine temperature is reached.While at road idle or accelerating, the vehicle runs smooth while below operating temp.The second the engine reaches normal operating temp the engine will give a little jerk/buck. From then on when accelerating, the enginefeels as though it is starved for fuel OR there is inadequate spark advance at distributor. At road idle it will give a little burp or stumble slightly occasionally. As though a control valve operates, when it warms up, causing a vacuum problem?
What do you think?
Old Jun 25, 2008 | 11:36 AM
hondadude's Avatar
Default RE: Stumbling only after temperature reached
On the distributor there are 2 diaphrams, one of them is the cold start advance, the other is the advance for normal operation.
You can manually test them to see if one of them will not hold vacum.
I will recommend you take the vacum lines loose from the metal line when testing, the plastic nipple on the vacum advance is easily broken.
Also the hot air door diaphram on the breather snorkle needs to be checked.
If you can't find any problems with the diaphrams repost.
spartan615
Sep 4, 2010 09:43 PM
KevinAccord
Jul 14, 2008 11:03 AM
skyking007
Sep 6, 2007 07:33 AM
Karthigan
Nov 27, 2006 02:55 PM
Sellmanb
Dec 27, 2005 03:02 PM
