Stupid Me
Old Aug 22, 2014 | 10:26 AM
vanman23's Avatar
Default Stupid Me
This is my first post and in desperate need of help. To get to the point, I need to know the capcitor at C41 of the TCU for a 92 Accord. I damaged it (cut it in half) when I was trying to cut the grommet off to remove it from the case. All I can see on the half of capacitor is 10. The other capicitors near it and about the same size are 103Z. If anyone can confirm this or let me know what it is, I'd appreciate it.
Here is the story of how I got here. Solid D4 on start up. Transmission would not shift out of 3rd or 4th gear (not sure which one). It will manually downshift to 1st or 2nd gear (not sure which one). I found on this forum, it could be TCU and I pulled it out. There is a burned resistor and leaking capcitor(s). And then the above happened.
I'm too cheap to buy a remanufactured TCU and to lazy to go to the salvage yard to pull a TCU.
Thanks in advance.
Old Aug 22, 2014 | 11:34 AM
When I googled "capacitor 103z", the following popped up. Looks like 0.01 uf capacitor.
Xicon 140-100Z5-103Z Ceramic Disc Capacitors | Mouser
https://answers.yahoo.com/question/i...3143408AAKXI8t
Old Aug 22, 2014 | 11:36 AM
Edit: If C41 is not a radial capacitor, then what TexasHonda posted would be the closest thing.
Based on pictures posted on the web/internet and the capacitors/resistor repair kits on ebay, there supposedly are 5 radial capacitors and this is what it appears like to me:
C28 220uF 35V 105℃
C32 330uf 10V 105℃
C33 33uf 35v 105℃
C27(?) 4.7uf 50V 105℃
? 1uf 50V 105℃
(2) 15 ohm 1/4 watt resistors
Shikaro
40
Oct 3, 2007 09:46 AM
justcallme61
Jun 2, 2007 09:53 AM
marbro
Dec 4, 2006 04:23 AM
Sparco_racingVTEC
Aug 26, 2006 10:09 AM
calenatar
Feb 15, 2006 04:05 PM
