stupid problem
Old Feb 1, 2008 | 05:49 PM
4montecarlo's Avatar
Default stupid problem
i cant find my pcv. i have looked in the haynes manual, but it is not very specific, and i have been unable to find it searching this site either.
i have a 1987 with a carb. I know it has to be someplace obvious.
thanks for any help
matt
Old Feb 1, 2008 | 06:03 PM
Default RE: stupid problem
It will be on top of the valve cover and have a hose going to the intake manifold.
Old Feb 2, 2008 | 09:57 AM
i would have thought it was there also
but the only vacuum line coming off the valve cover goes to the box on the side of the air filter houseing. And that line is connected to the valve cover with a metal line with no pcv, unless its under the valve cover? The haynes book says to test pcv clamp that hose shut and idle should change. that is the correct vacuum line, right?
thanks
matt
Old Feb 2, 2008 | 10:41 AM
sir_nasty's Avatar
it almost sounds like someone removed the pcv valve and replaced it with a metal fitting.... The line normally comes off the pcv in the valve cover then a rubber hose goes to the intake, so if it's not there perhaps it's missing?
Old Feb 2, 2008 | 12:18 PM
HondatechAV6's Avatar
i believe the pcv is a metal screw in type in the intake manifold.
Old Feb 6, 2008 | 10:36 AM
and does anybody know where in the intake it is?
thanks
matt
Old Feb 9, 2008 | 09:30 AM
ttt, anyone know where in the intake its at?
thanks
matt
Old Feb 9, 2008 | 10:56 AM
oma93's Avatar
Since you can't seem to find it, go to autozone or advance or whatever. They can point it out to you easily.
Shikaro
40
Oct 3, 2007 09:46 AM
justcallme61
Jun 2, 2007 09:53 AM
marbro
Dec 4, 2006 04:23 AM
Sparco_racingVTEC
Aug 26, 2006 10:09 AM
calenatar
Feb 15, 2006 04:05 PM
