Stuttering at 4000
Old Jan 30, 2006 | 10:16 PM
fineaccord
Default Stuttering at 4000
I have a 98 Accord EX 4 cylinder and after it has ran a while when the tach hits around 3800 to 4000 it is like the engine has hit the rev limiter. When I let off of the gas everything goes back to normal. I have replaced the VTEC modulator, plugs, plug wires, distributor, and rotor button and it is still doing this. Any suggestions? Also after you turn the engine off and start it again it does not do this until after it has ran for a while.
Today after replacing the plugs, wires, and distributor got on the interstate went three exits and everything was fine. Turn around to come back and it started this and when I shut it off and started again it did not do this.
Old Jan 31, 2006 | 09:25 PM
EMEX's Avatar
Default RE: Stuttering at 4000
It could be a number of reasons actually, like your valve timing could be off. I'd suggest you take it to a mechanic and get it tested. It's most likely the problem with timing.
Old Jan 31, 2006 | 11:47 PM
lightshow's Avatar
you replaced the modulator? or the solenoid? could be the solenoid. also if your low *** on oil your vtec wont engage.
lightshow
MrDrummond
Jun 30, 2011 12:18 PM
Nhar
Feb 22, 2009 07:55 PM
majikmajisto
Mar 14, 2008 01:36 PM
milano_6
Sep 27, 2007 05:57 PM
greenete
Jan 21, 2007 09:37 PM
