suspension
Old Aug 27, 2008 | 11:57 AM
rhobere's Avatar
Default suspension
My co-worker has an 01 ex 2-door. Recently she had a blow-out and noticed that the front driver-side tire was sitting crooked. From the looks of it, there's a verticle barthe comes up from the hub assmebly that is noticeably bent.Another one of my co-workers called it a spindle, but she can't find any replacement parts under that name. Any ideas what it could be?
Thanks
Old Aug 27, 2008 | 02:05 PM
rhobere's Avatar
Default RE: suspension
Ok, I went and looked at it so I can be a little bit more specific about it location. Its an upright that runs from the upper control arm to the lower A-arm. It bent bad enough that it actually pulled out the upper ball-joint.
Old Aug 27, 2008 | 02:30 PM
There are two images on here from a parts website (www.hondapartsdeals.com) for an 01 Accord. Let us know if any of the parts are the ones that are bent.
[IMG]local://upfiles/5767/65FA9D88E8054B838AA300D1223F5034.jpg[/IMG]
Old Aug 27, 2008 | 03:26 PM
rhobere's Avatar
Its kinda hard to read, but it looks like 15. (the second component from the left on the bottom picture)
Old Aug 27, 2008 | 03:54 PM
That picture is pretty high resolution. When you click on the link below it, you should be able to zoom in and still see things very clearly.
The second item from the left is the knuckle. It is labeled #1or#2. Just to be clear, this is a big cast iron piece that holds the brake, rotor, hub, and the tire?
I always find Ebay useful to identify parts. Just search "accord knuckle" without the quotes and look at the pics. Remember the front and rear knuckle look a lot different.
Lowered96Accord
Apr 19, 2008 08:35 PM
George Knighton
Jan 11, 2006 08:49 PM
Shocker
Jun 10, 2005 07:19 PM
hongu
Jun 8, 2005 09:38 AM
sHiNoBi
May 26, 2005 11:42 AM
