Sponsored by:
Sponsored by:
Sway Bar Bushings and Links
Old 08-29-2012, 01:13 PM
tobybul's Avatar
Default Sway Bar Bushings and Links
Just picked up a 2000 Accord EX V6. Replaced the sway bar bushings and links. Bushing on this car is 27.2 mm. Very easy to do. Links were a bit more work. The top side was tough to unbolt. Started with my impact wrench first. Bolt eased out slightly until shaft started turning. Then used ratchet and Allen wrench to counter it. Bottom came off fine but ended up stripping the center Allen hole of top 14mm bolt as I was turning the bolt. Ended up cutting it with cutting disk.
Replaced link with sealed type that I got from Import parts store. Other stores (napa, oreilly) had greasable types but prefer I sealed type.
Tip: I used the original nut on the bottom side. Its a taller nut and will be easier to grab on to when the time comes to replace the link again. The nut that came with the new link was not as tall.
Old 02-19-2014, 04:52 PM
Can you please give me some instructions on how to do the same procedure? I have the same vehicle, V6 Coupe, and I'm trying to replace the sway bar end links and bushings.
Old 02-19-2014, 06:27 PM
tobybul's Avatar
Corey, what more do you need to know besides what I already wrote up? Let me know.
Old 02-20-2014, 09:22 PM
Can you write up in more detail the procedure for removing and reinstalling the bushings?
Old 02-20-2014, 09:24 PM
Old 02-20-2014, 09:36 PM
tobybul's Avatar
Originally Posted by PAhonda
No need to do call that on 2000 accord. Just unbolt bushing clamp. Pop out old bushing. Install new bushing. Reinstall clamp.
Old 02-20-2014, 09:42 PM
I misread your post. That video is for the links (if you are replacing) and not the bushings. The bushing is in the middle (there are two). Just remove the the two bolts on the strap/cap, remove rubber bushing. Replace bushing, then bolt the metal strap/cap back on.
LANman
05-16-2012 01:22 AM
tony11
03-22-2010 07:25 PM
Calevra18
09-12-2007 08:29 AM
ArcticHonda
12-13-2006 11:49 PM
casanova06
09-29-2006 10:41 AM
Quick Reply: Sway Bar Bushings and Links
