Tail Lights staying on?
My tail lights are staying on even with the car off and headlight (nighttime running lights) switch turned off. This is causing the battery to drain and preventing me from driving my car. Let me state again that it is the tail lights, NOT THE BRAKE LIGHTS. Everything I have read says it is the brake switch but that doesn't seem right to me because its not the brake lights. ANY help would be greatly appreciated.
Thanks in advance,
Drake
Forgot to mention, It is a 1996 Lx model 4door 2.2sohc
Thanks in advance,
Drake
Double check....have someone/somthing press the brake pedal and view the "lights" in both situations.
If it is the running lights staying on, then I hope you have a volt meter for the fun to begin......I hate electrical issues.
Reviving an old post here. Was this problem ever resolved? I'm having the same problem on my 98 Accord. The tail lights are staying on. The front parking lights are off. It is not the brake lights that are on. The lights in the trunk panel are also on. However, the side marker lights in the rear bumper are not. It is only the lights across the back. The brake lights work properly when pressing the pedal.
What trim level is your Accord (e.g., EX, LX, DX, etc.)? Even in your generation Accord, there are slight differences in the circuits depending on trim level.
