temp gauge on 99 accord
Old Feb 3, 2015 | 09:34 PM
dr.deuss's Avatar
Default temp gauge on 99 accord
I have a 99 v6 accord that I put the engine out of a 01 in. I swapped ecu and wire harness. Everything works great except the temp gauge. I know the 99 has 1 sensor for the temp and the 01 has 2. But I am unsure of what to do to get the gauge working.
Any help is appreciated
Old Feb 3, 2015 | 09:54 PM
It's the opposite regarding the number of sensors between the 99 and 01 V6. On the ’01 Accord, the coolant temperature gauge and ECM/PCM are controlled by a single ECT (engine coolant temperature) sensor. The 99 had two sensors: a coolant temperature sending unit for the gauge, and an ECT sensor for the ECM/PCM.
1. Is the Yel/Grn wire from the ECM/PCM properly connected at terminal no. 1 of Connector A (32P connector at the ECM/PCM)? The ECM/PCM sends the engine coolant signal via the Yel/Grn wire.
2. Does the Yel/Grn wire make a proper connection at the gauge assembly?
3. With ignition ON (II), there should be pulses on the Yel/Grn wire.
Old Feb 3, 2015 | 10:00 PM
Looking at the diagram for the 99 and the 01, the 99 accord temperature gauge in the dash is controlled by a temperature sending unit. The 01 temperature gauge is controlled by the PCM (engine computer).
Which wire harness was replaced when you swapped the engine and PCM?
Old Feb 4, 2015 | 05:30 AM
dr.deuss's Avatar
I cant quite remember but I know the motor is from an 01. I think the harness from a 00 and the computer was possibly from a 01.
Its been a while since I actually did the swap. So with the car on should I just use a tester on the yel/grn wire and see if its getting a reading
Old Feb 4, 2015 | 11:30 AM
Yes, with the ignition switch in the ON (II) position, you can test for a pulse signal at the Yel/Grn wire.
1. At the green Connector C (16P connector on right side) of the gauge assembly, terminal no. 2, check for a pulse signal.
2. If there is no pulse signal on the Yel/Grn wire at the gauge assembly end of the harness connector, then check for a pulse signal at the Yel/Grn wire at the ECM/PCM side (terminal no. 1 of Connector A - 32P connector). -- You may have to backprobe the ECM/PCM harness side.
3. If there is a pulse signal at the ECM/PCM; but, not at the gauge assembly end, then you would unplug both ends of the harness connector, and then test for continuity of the Yel/Grn wire by using an ohmeter/multimeter by touching the leads at both ends of the harness connectors.
The harness wires that go between the ECM/PCM and gauge assembly for the temperature gauge, goes through a separate 16P gray connector (located behind the driver's dash lower cover).
SVTMike
Jun 2, 2013 10:51 AM
pirulino23
Nov 10, 2010 06:18 PM
segen77
Dec 9, 2007 06:55 PM
raf105
Sep 28, 2007 02:55 PM
zoominhuman
May 30, 2007 06:08 PM
