Temp gauge fluctuating
Old Mar 5, 2016 | 07:37 AM
BlackLX4's Avatar
Default Temp gauge fluctuating
Temperature gauge is fluctuating relatively slowly, particularly after a longer drive. My wife drove the car to the city this morning (about an hour and a half drive at 55 mph), and she told me that the temperature gauge was at about 3/4 to H. It will read anywhere from about 3/8-5/8 normally, but I know it shouldn't be fluctuating much, if at all. Usually I can see it kinda creep up to around 5/8 when I'm coasting down to make a turn, then as I open the throttle again it quickly drops back down to around 3/8. Brand new ECT sensor and sender installed and system flushed when I replaced the head gasket about two weeks ago; thermostat, hoses, and radiator (came with cap) replaced a few months ago. Could it just be that I got a faulty part out of the box?
Old Mar 5, 2016 | 11:25 AM
Make sure both cooling fans are engaging when temp reaches ~ 195F. A IR temp gun is handy for this.
If thermostat was not an OEM thermostat, suggest trying a replacement. I have had aftermarket thermostats control temperature poorly.
Old Mar 5, 2016 | 03:39 PM
BlackLX4's Avatar
Both cooling fans are kicking on when the t-stat housing is at about 187-188 degrees F.
Old Mar 5, 2016 | 04:39 PM
Did you use a Honda thermostat?
Old Mar 5, 2016 | 04:52 PM
BlackLX4's Avatar
No. It was aftermarket. Went ahead and ordered OEM.
Old Mar 5, 2016 | 05:41 PM
Install the Honda thermostat, then refill and bleed the coolant. Then report back if the problem went away or remains.
Old Mar 7, 2016 | 11:13 AM
If this happens while driving, especially at highway speeds, don't bother looking at the fans. At 30 mph, there's already more air from the car's motion than what the fans can provide.
Instead, the thermostat is a better place to look. And don't forget to bleed out the air bubbles - bleed screw on the thermostat housing. Honda cooling systems don't like to have any air bubbles inside.
Old Mar 12, 2016 | 08:16 PM
BlackLX4's Avatar
Put in the OEM t-stat a couple of days ago, and so far so good! The needle stays at a steady 3/8 under all conditions. Thanks again, guys!
IllusionistK
Aug 31, 2011 06:56 PM
pirulino23
Nov 10, 2010 06:18 PM
adamc44
Jul 13, 2008 10:37 PM
AKcord
Mar 29, 2007 01:44 AM
wietgr
Dec 24, 2006 02:47 PM
