temperature gauge
Old Mar 8, 2007 | 06:09 PM
vishawn
Default temperature gauge
hey all, quick question. my temperature gauges keep going all the way up to "H" when i start my car. any ideas as to the problem? its been like this for about 3 yrs, the car has never overheated.
Old Mar 8, 2007 | 07:37 PM
Default RE: temperature gauge
It could be a the wire going to the temp gauge is grounded, or the engine coolant temperature sending unit is bad.
The sending unit is near the thermostat and has a YEL/GRN wire going to it on my 95. The resistance from the tip to engine ground should be 32-49 ohms when you are at operating temperature and around 142 when the engine is cold. An internal short in the sending unit could be causing your problem.
If you unplug the connection and your gauge should stays at the cold mark, then your wire isn't grounded between the sensor and the gauge.
Old Mar 8, 2007 | 08:21 PM
hondadude's Avatar
What "COLOR" is the car?
Old Mar 9, 2007 | 07:15 PM
vishawn
color of the car = bmw m3 blue also known as Laguna seca blue
Old Mar 9, 2007 | 08:08 PM
hondadude's Avatar
ORIGINAL: vishawn
Sorry I can't find any info for a 79 Accord with Laguna seca blue paint;
Zing ...Zing; it must still be going right over your head.
Old Mar 11, 2007 | 11:46 PM
vishawn
Old Mar 12, 2007 | 01:19 AM
Hondadude wants you to put the year, make, and model so people will help you out.
moto64
Mar 31, 2008 09:53 PM
Jcaleno
Apr 17, 2007 01:24 PM
mdubb99
Jan 30, 2007 07:54 PM
Karthigan
Nov 27, 2006 02:55 PM
mycargov6room
Jul 7, 2005 10:28 AM
