Testing EGR Valve
Old May 3, 2012 | 10:43 AM
bnwbass's Avatar
Default Testing EGR Valve
Hello all,
1993 2.2, did not pass smog for High NOx, tech says could be EGR. The car has 213K and have never done any maint on the EGR in terms of cleaning ports or replace EGR valve.
Question: I put a hand vac pump on the EGR port and try to hold vac at 10 in.HG to see if the diaphragm will actuate but nothing. Wont hold Vac.
Does this indicate torn diaphragm and the EGR needs to be replaced, or will a good cleaning of the EGR valve body itself maybe fix it to working condition.
thx
bw
Old May 3, 2012 | 10:56 AM
Dr. Drivability's Avatar
You can pull the valve off and check the ports, if the ports are clear and the valve pintle lifts when you apply vacuum, then you have a control issue...this system has a lift position sensor and a solenoid valve controlling it.
Old May 3, 2012 | 03:14 PM
bnwbass's Avatar
Thx, pulled the EGR, when apply vac the valve pintle lifts and then retracts right away. Is this normal? There is a lot of soot that I will clean out but it seems to move freely. Can the sensor be checked? or replaced separately. It appears that the only way to change the sensor is to buy a new Valve. When you say control issue, dose this mean that if the ports, runners are clogged then this contributing to the problem?
thx
Bw
Old May 3, 2012 | 04:16 PM
if you apply vacuum and the valve lifts and then loses vacuum and drops right away, the valve is bad. clean the ports while you're at it as well.
by control, i'm referring to the ecm, but your valve is bad, so it needs to be addressed first anyway.
Old May 4, 2012 | 09:32 AM
bnwbass's Avatar
Thanks for the reply Dr. If I plug both openings on the ERG on the bench it holds vacuum. Are you saying that it should hold VAC with the ports open to atmosphere?
thx
Bw
Old May 4, 2012 | 11:28 AM
i'm fairly sure the valve is bad, but send me your email and i'll get you the specific diagnostic procedure...it's pretty straight forward and we won't be guessing.
Old May 4, 2012 | 11:55 AM
bnwbass's Avatar
I cant find anywhere on the forum to send you a private message
Old May 4, 2012 | 12:30 PM
click on my screen name and it will give you the option of send a pm
Old May 5, 2012 | 05:38 PM
bnwbass's Avatar
Thanks for the response.
This is what I have done so far:
1. Removed EGR valve and cleaned toughly, the valve pintle move freely and looks good.
2. Cleaned all EGR ports with recommended cleaner and runners with small nylon bottle brushes all clear.
3. Reinstalled EGR with new gasket and put everything back together.
4. Started engine warm-up and then removed vac line #16 to the EGR Engine does not stall or run rough
6. Apply Vac at the EGR with hand pump but EGR won’t hold Vac.
If I pump the hand pump quickly in repetition I can get the engine to stall so I know the EGR ports are clear and EGR valve is moving to some degree.
Does this all point to a bad EGR valve? According to the flow chart troubleshooter it does.
Thx Bw
Old May 5, 2012 | 06:41 PM
Sounds like it.
evilklown
Feb 15, 2013 05:56 PM
NZXTInerTia
Jul 20, 2012 03:06 AM
archangel_1988
Dec 13, 2011 11:43 PM
olgirlkeepsrunnin
Jan 31, 2010 02:37 PM
RJLhonda
Sep 9, 2008 01:05 AM
