There is leak - Help please
So both scenerios are safe?
yes, if its clear liquid, its water. water that is condensing on the evap. because it's 100 degrees and humid. if you look under your car on the passenger side towards the very rear of the engine bay (fire wall) you should see a tube where the water is coming from (that is the drain tube for the evap). you can confirm thats where its coming from, then you are sure thats what it is.
Your A/C drain tube may be plugged up. You can get at it from inside the cabin if you gently pull the carpet away from the firewall. I was getting water fron the AC in mine and found the tube by accident while searching for the leak. Use a compressor to blow the tube out.
sorry to jump in on this thread. i think i have the same problem. there is probably around a drip per second coming from what sounds like the same place on my 2007 coupe.
i live in california, so i'm not using ac, and it's not really humid enough for condensation to build up.
hobieslug45 - where you able to find out what was wrong?
ryanmunce
May 29, 2007 06:42 PM
thunder_x
Feb 19, 2007 01:38 AM
bougie_44
Jul 27, 2006 02:11 AM
