thermostat 93 accord
Old Jan 24, 2011 | 05:35 AM
rgstanley1's Avatar
Default thermostat 93 accord
i have 2 questions.
question1
i replaced the thermostat 2 weeks ago on my car after i noticed the hose was not hot after driving all day and the car was running very sluggish. That seemed to solved the problem for about a week. I notice yesterday it was driving sluggish again. i checked the hose and it wasn't hot. Could the thermostat be bad this soon? Or is something else going on?
question2
smoke coming out tail exhaust and burning alot of oil so i had the valve stems replaced. still smoking and burning oil! is there something else going on?
Old Jan 24, 2011 | 08:16 AM
How about plugged tubes in the radiator? How clean was the antifreeze? How clean was the inside of the T-stat housing?
Old Jan 25, 2011 | 03:48 PM
rgstanley1's Avatar
antifreeze was very clean and the thermostat housing. what do you mean plug tubes in the radiator?
i added 4qts of oil yesterday and changed the thermostat again. i had to add 3 more qts of oil but the thermostat is working as of now.
Old Jan 25, 2011 | 07:05 PM
Hang on, if I'm reading this correct. Seven qts of oil in two days? I'd do a compression test. Sluggish, I'd bet the plugs fowled with oil. You are sure it is not leaking, but burning the oil.
Old Jan 25, 2011 | 08:46 PM
The internal water passageways inside the radiator can get obstructed with scale & crud. Since the inside of the thermostat housing was very clean, this is less likely to be a problem.
Maybe something is visible in the radiator cap? Whenever I drain the antifreeze or open the T-stat, I try to look around as best I can inside the hoses & inside the radiator.
SEVEN QUARTS IN TWO DAYS? That's an outragous amount of oil. Keep looking to figure this out.
honda285
Dec 16, 2008 07:28 PM
lashlecf
Jun 2, 2008 11:41 AM
cbrf4i1
Jan 6, 2008 05:08 PM
nukem384
Dec 11, 2006 08:09 PM
bwaymire
May 26, 2006 02:04 AM
