three problems with 94 accord 5speed.
car runs with new clutch.(just finished.)
but now all of a sudden when i test drove the car up the street it said my e brake was on (it wasent) what could cause this?
also when i started the car up its idle was going up and down. (between 2000 and 1000)
also can anyone tell me on there accord for the 02 sensor the wires that go into the connecter(my 4 wires came out of the connector) green white and two blacks. which holes do they go in??
Brake warning lamp is also triggered by low brake fluid. Check that. There's a float switch in the cap of the brake fluid reservoir. Sometimes the float hangs up on the mesh basket inside the reservoir. There's a replacement basket, or you can whittle some of it with an x-acto knife so it doesn't interfere with the motion of the float.
Or maybe the switch at the handbrake handle is flaky??
For the idle, look in the DIY section for a post about setting the BASE idle and forcing the car to re-learn the idle. But don't bother doing that until you get the O2 sensor sorted out. Right now, I don't know the pin=out for that plug.
Yeah, or anything with cooling system. Did you drain coolant during the clutch R&R? Bleed all air out of the system? Is the T-stat old?
Did you do anything with the wiring harness at the temperature sensors? Those are in the end of the head sorta below the distributor. The sender with only one wire is for the dashboard gauge. Any chance that wire is pinched & grounded?
the four wires are 2 black 1 white 1 dark green i have a f22b didnt figure it out.
as far as the over heating i think i got that all taken care of. brakes takin care of.
now i noticed when i first poured oil in the car after new clutch i chaged the oil put 5qt's in and it didnt show any on my dipstick. why??
