Throttle body spacer
Old Nov 2, 2007 | 02:18 PM
gunsnroses316's Avatar
Default Throttle body spacer
Does a 98 accord 4cyl throttle body spacer fit 98-02 V6or will it just fit 98-02 4cyl
Old Nov 2, 2007 | 02:27 PM
sir_nasty's Avatar
Default RE: Throttle body spacer
it's a worthless piece of crap unless you're doing NO2 so I wouldn't waste money on it
Old Nov 2, 2007 | 02:52 PM
Fenix's Avatar
I second that statement, does absolutly nothing
Old Nov 2, 2007 | 04:12 PM
tkundert2's Avatar
An engine with acarburetor can be affected by spacers, but what would be the point of a spacer with a fuel injected engine?
Old Nov 2, 2007 | 09:10 PM
Velocifero's Avatar
ORIGINAL: tkundert2
no one knows for sure. in fact on v6performance, some guy dynoed with it and had gains. ive got one, but dont like it. after my next dyno ill know for sure if it does anything.
Old Nov 3, 2007 | 03:09 AM
2POINTautO's Avatar
The spacer on carbs just gave an added inch for the air to get straightened up, turbulant air is bad for the engine, unless its designed for turbulant air, it should have no real effect on a FI engine since the intake manifold is a surge tank (Japanese name) to help smooth the air flow out, now, a spacer between the intake and head, I would give that a try.
How about the guys who use the four throttle system from Toyota Levin on their Hondas. No surge tank, ya baby.
Old Nov 3, 2007 | 08:02 AM
falkore24's Avatar
ORIGINAL: sir_nasty
...unless you're doing NO2
hehehe ........ [sm=nxsmile.gif]
Old Nov 3, 2007 | 11:25 AM
sir_nasty's Avatar
ORIGINAL: 2POINTautO
It also helps the carb stay a bit cooler and that improves performance as well.
Old Nov 4, 2007 | 04:40 PM
00AccordLX5spd's Avatar
Registered User
I also heard it may make your intake a little louder
Old Nov 4, 2007 | 07:24 PM
Velocifero's Avatar
ORIGINAL: 00AccordLX5spd
theres a "whistle" around 2-3k and usually anytime at WOT. it sounds a little like a turbo and makes a neat "psh!" sound when i hit the gas after shifting gears. just enhances the natural intake sound i think. id rather not have it.
Stanley9875
Feb 4, 2009 05:49 PM
Mdschmidt
Oct 6, 2008 08:24 PM
WRX_ACCORD_136
Aug 28, 2008 11:51 AM
myrtle71590
Jun 29, 2007 02:00 PM
mikel6690
May 9, 2007 02:45 PM
