Throttle Stop Screw Stuck
Old Apr 19, 2012 | 12:39 PM
curtie94's Avatar
Default Throttle Stop Screw Stuck
Hi I have an issue with my 91' Accord. When I let go of the gas the butterfly catches and I have to slam the pedal to get it to move again. I looked and noticed that the throttle stop screw is away from the throttle. I tried to adjust it back up so the pedal is good, but it won't budge. It is almost seized in, the same thing with my Idle Air Screw. How can I get these to loosen up, I've tried wd40 and a little bit of heat, but still nothing.
Old Apr 19, 2012 | 12:53 PM
hondadude's Avatar
Have you tried this?
Old Apr 19, 2012 | 03:05 PM
curtie94's Avatar
yes, I just jerry rigged it so it would't catch onto itself, I ended up finding and piece of plastic that fits perfectly onto the stop screw and pushes the throttle just enough so it won't stick, but doesn't accelerate.
Old Apr 19, 2012 | 03:44 PM
crispin's Avatar
sounds super safe - great job!
Old Apr 19, 2012 | 04:21 PM
curtie94's Avatar
The cars a 5 speed so I'll be able to press the clutch in if anything happens, but nothing should happen. It fits right around the stop screw and is glued on with silicone gasket so it will come off when I want it to.
Old Apr 19, 2012 | 08:21 PM
Don't think the "stop" is adjustable.........how much slack is in the cable?
I can't remember if you have a service manual or not? IMO, you've been beat up enough on other sites, I will try to help where I can.
If you don't have a service manual let me know and I can link you to a few choices...not the best but of some help.
Something like a vac cap over the top of the "stop" should be fine.....I think that is what the OE set up is like? Been a while.
Attached Thumbnails Throttle Stop Screw Stuck-4th-gen-idle-stop.jpg   Throttle Stop Screw Stuck-4th-gen-throttle-cable-adjustment.jpg
Old Apr 19, 2012 | 09:20 PM
curtie94's Avatar
Thanks for the help, Im not sure if it is adjustable either, but will my set up work for now? It works good and is removable if need be.
Yes I do have a manual,
The throttle cable is adjusted correct I actually had to loosen it because it had no free play and made the throttle stay open a little so it would idle at 1000.
Old Apr 20, 2012 | 06:25 PM
According to the manual, see pic, the stop is not adjustable.
If I remember, hint to remind me as I'm old and forget things, I'll send you a PM about something I've seen some do that might have led to this issue.
Lenno
Jan 29, 2012 07:45 PM
Al_S
Jun 26, 2010 08:17 PM
husky100
Jan 1, 2008 06:30 PM
xaznxeclipsex
Sep 28, 2007 02:05 PM
badxdawgx818
Sep 4, 2007 03:36 PM
