Thumping when braking passenger rear..
Old Mar 19, 2011 | 02:50 PM
Bobby1964's Avatar
Default Thumping when braking passenger rear..
03 Honda Accord EX L ... changed brake shoes, turned rotors last year but intermittently when braking I have a thump thump thump when applying the brakes at low speeds BUT when i slightly engage the parking brake it goes away. If I leave the parking brake slightly engaged it will thump on the rear passenger side anytime, regardless of whether the brakes are being pressed or not.
I have taken it to the Honda mechanic who did the job and he said he needed to turn the rotors... I don't think that is it due to the previously stated symptoms.
Turning that rotor with close to 100k will probably mean buying new rotors.. So before I do that I figured I would ask here since I've looked here many times for answers.
Thanks
Old Mar 19, 2011 | 09:56 PM
I'm confused with your post. Are your rear brakes a shoe/drum setup, or a caliper/rotor setup?
Old Mar 20, 2011 | 07:01 AM
Bobby1964's Avatar
Stock 03 accord ex... Caliper/rotor setup...
Old Mar 20, 2011 | 08:04 AM
Ok a few things to think about. Does this only seem to happen when you first start to drive.
I'd pull the wheels and inpsect everything-pads, hardware, mounting bolts, ect.
lovethequeen
Aug 24, 2023 05:14 PM
Rilex
Jun 30, 2014 04:44 AM
michaelm871
Jun 15, 2013 10:48 AM
Reggi's-accord
Aug 10, 2012 07:21 PM
