timeing belt
Old Jul 22, 2008 | 03:08 PM
Default RE: timeing belt
If your rings go bad, or you spin a main bearing, you have to dismantle the crankcase & remove the pistons, etc. Thats not routine, its not done on any kind of schecule, its a major repair. Often its an excuse to replace the engine.
Old Jul 22, 2008 | 03:11 PM
Tensioner #9 pushes against chain guide #11. When tensioner runs out of travel, it leaves slack in the chain. Problem is, I dont know whether its spring-loaded or driven by oil pressure. Probably both. Probably have to remove lower timing cover. I havent done this yet...
Old Jul 22, 2008 | 04:36 PM
Grab the chain where the #8 label is in the illustration, pull it away from the sprocket.
Old Jul 22, 2008 | 05:28 PM
Theres probably a spec for that.
Old Jul 22, 2008 | 05:39 PM
The sprocket teeth are so deep like a bicycle chain that it takes a tremendous amount of stretch before it can skip a tooth.
Old Jul 28, 2008 | 11:15 PM
Little cover #2 allows you to see the tensioner.
Allowable extension = 13.5mm.
ibettysman35773
Apr 19, 2013 06:09 PM
schoust
Apr 7, 2012 04:38 PM
AcCoRdLoV1998
Jun 27, 2009 09:21 AM
Jeff247
Dec 29, 2006 07:15 PM
