timing Belt - Age vs Maintenance Minder
Old Jun 26, 2024 | 02:25 PM
tchestman88's Avatar
Default timing Belt - Age vs Maintenance Minder
I have a 2017 Honda Accord 3.5L V6 coupe, 34,600 miles. I was told by several mechanics that it is recommended to get the timing belt done, since it has been 7 years owning the car.
Should I wait until the maintenance minder comes on or do I just get the timing belt done regardless? Looking forward to what you think. Thanks!
Old Jun 26, 2024 | 03:55 PM
kris_loehr's Avatar
I have always ignored age and just considered miles on a vehicle for wear until I took my 2014 Accord apart for timing chains and related parts. I have just 91,0000 but even the bolts on everything were either rusted to a point of needing replacement or seized. The water pump looked perfect but the seal was falling apart. Valve cover and oil pan seal were leaking. I would change your timing belt and front seals. Do you have any oil leaks in that area?
Old Jun 26, 2024 | 10:24 PM
Thanks Chris. I don't have any leaks, and I appreciate your advice.
Old Jun 27, 2024 | 09:45 PM
2016firstcar's Avatar
Had a friend who ignored his timing belt and ended up with a hefty repair bill. personally, I'd rather spend a bit now than risk major engine damage later. just my two cents.
Old Jun 28, 2024 | 11:04 AM
Thanks for your reply!
Old Jul 11, 2024 | 02:04 PM
I was just at Honda. One of the service advisors told me to wait at least 4 more years or 60K miles. He told me the 7 year Honda requirement was just to make money, and my car that has such low miles does not need to have a new timing belt. I'm going to post this in the main forum, but just wanted you to know in case you may think he's totally wrong or what. Thanks!
Old Jul 13, 2024 | 03:55 PM
kris_loehr's Avatar
Some people use the serpentine belt condition as a gauge for timing belt wear.
Old Jul 22, 2024 | 03:37 PM
hardy1039's Avatar
FWIW...From another forum. I'd like to believe this post because I have a 2006 Accord V6 and have not replaced the timing belt.
https://community.cartalk.com/t/timi...mileage/150390
Old Jul 23, 2024 | 10:54 AM
75Gremlin's Avatar
very often timing belts last many years and miles longer than the factory replacement recommendation. My 2000 Civic has 106k miles and 14 years on the belt. I had a Miata and quite a number of folks on the Miata forum have early 1990s Miatas with the original timing belt and over 250k miles. However, the (Gen 1, at least) Miatas have a non interference engine so no big deal if the timing belt breaks.
in your case you have a relatively new car, so might be worth it to replace the belt. But my guess is that you could go several more years without a t. belt problem.
Old Aug 5, 2024 | 05:10 PM
nomad2020's Avatar
Some people use the serpentine belt condition as a gauge for timing belt wear as per KRIS
I hate to disagree with that statement ,not a good idea to compare serpentine belts to timing belt change time,, timing belt is totally covered , serpentine belts are not, they can dry and crack a lot faster cause they are exposed to the elements, water /dirt can get in them ,, If you do a lot of city driving 60-70 k is a good time to think about replacing t-belt , if it has 35k even if it's 7 years old I would not replace t-belt
pmay805
May 24, 2021 04:02 PM
Paddy
Oct 13, 2019 01:29 PM
562kid
Aug 27, 2011 10:11 AM
newyota
Jul 11, 2011 03:40 PM
ndj1521
Jan 28, 2011 04:46 PM
