timing belt/seal/water pump replacement DIY?
Old Oct 13, 2011 | 12:26 PM
cutlass327's Avatar
Default timing belt/seal/water pump replacement DIY?
I was reading in the Gen tech after searching a thread by Tony where it was mentioned a DIY thread. Has it been done? If not, could you do one? Mainly in the thread I would like to see how others have installed the seals in-car. I have seen the special tool that Honda has, but is there enough room? A socket with long bolt/nut/washer? Those tips would be nice in a DIY thread, besides the normal timing mark alignment, proper belt tensioning procedures, etc.
Thanks!
Old Oct 13, 2011 | 06:49 PM
Check in the Common DIY Threads for a how to.
Here is something that might help as well
"honda-tech.com/showthread.php?t=1908944"
Old Oct 14, 2011 | 10:07 AM
cutlass327's Avatar
That comes up "Server not Found".
I had looked in the DIY section, and couldn't find anything on it. Ther is only something about Door locks, HVAC codes, Parts manuals, and parts compatibility...
Old Oct 14, 2011 | 10:11 AM
take the " off and add the www.
Old Oct 15, 2011 | 07:07 PM
cutlass327's Avatar
ah-ha!! thx!
pimpp1184
Nov 5, 2009 09:55 AM
mark95
May 18, 2009 11:47 AM
carbonatd
Jan 19, 2009 12:14 PM
quietgiant
Feb 10, 2007 12:26 AM
