Timing belt tensioner pulley
Old Jan 30, 2014 | 08:52 PM
Not sure's Avatar
Default Timing belt tensioner pulley
Hi everyone. I have been working on a 1992 accord 2.2 DX trying to change the water pump and timing belt. I got past the stubborn crankshaft bolt. now I cannot release tension on the timing belt. I cannot remove the center bolt. anybody have any experience with this or ideas of how to get it off. Is it reverse thread? Is it a long shaft bolt?
Thank you
Old Jan 31, 2014 | 02:02 AM
holmesnmanny's Avatar
You don't remove it. You loosen it a half a turn, push the tensioner in and tighten it gently then remove the belt.
Old Jan 31, 2014 | 08:11 AM
Roader's Avatar
It looks like a bolt but it's actually a closed-end nut. Regular, right hand threads. Sometimes it can be really tight. Use a 6-point box end wrench if possible to keep from rounding off the nut; vice grips if the nut gets rounded off.
Old Jan 31, 2014 | 09:23 AM
Not sure's Avatar
Unfortunately my first turn rounded off the nut. I have tried vice grips and pipe wrenches and lube. It will just not move. I see a little flat black washer up against the pulley, that does not need to come off first does it? If so, how? Thanks
Old Jan 31, 2014 | 09:50 AM
Tony1M's Avatar
You can see the threaded shaft poking out of tensioner in the 14th photo down in this post:
https://www.hondaaccordforum.com/for...977/#post24167
As I reported in that post, mine was a bugger to get off, too. I recommend first heating the nut with a propane torch, then try loosening again.
Good luck
Old Jan 31, 2014 | 11:32 AM
Not sure's Avatar
Good luck
I went to the junkyard and got a nut. At least now I know what I am trying to take off. I wish mine came off as easy as that one. Thank you for your help
Old Jan 31, 2014 | 01:53 PM
Not sure's Avatar
Finally was able to loosen mine today. After rounding it out terribly ended up using pipe wrench with a cheater from the bottom and heated it up with propane torch. What a pain in the $&@
Old Jan 31, 2014 | 01:54 PM
Not sure's Avatar
Finally got it. Thank you for the responses. Now to fight with the water pump
Old Jan 31, 2014 | 02:35 PM
Roader's Avatar
A touch of anti-seize on the tensioner stud wouldn't hurt. Definitely use anti-seize on the crankshaft pulley bolt threads and washer.
Old Jan 31, 2014 | 08:14 PM
This nut is always very tight. I use a closed end wrench and hit wrench end w/ hammer from below w/o problems.
Temptation is to really tighten very firm, however just firmly tight is adequate. Spec is 33 ft-lbs on 94 Accord.
