Timing belt & water pump
Old Dec 13, 2006 | 05:16 PM
kimh's Avatar
Default Timing belt & water pump
I am getting the water pump and timing belt maint. done on my car in the next week or so. I'm going to the dealership to get the water pump, timing belt & the 3 other belts. Is there anything else I should get while I'm there since I've having a private mechanic do the work? Also, I called the dealership and ask if there was anything that needed to be done to my car to "winterize" it and they said the anti-freeze gets changed during the above maintenance. If so, should I buy the Honda anti-freeze or does it matter? I read on here something about the valves or something getting replaced while doing this work. Just trying to get a list of everything I need to get while at the dealership to avoid more than one trip. Thanks!
Old Dec 13, 2006 | 06:07 PM
hondadude's Avatar
Default RE: Timing belt & water pump
On the 6 cylinder, replace the shaft seals, cams, and crank None of the seals will make it to the 2nd T-belt change.
yep, I'm a firm believer in the new Honda type 2 blue coolant, smells good too!! LOL
quietgiant
Feb 10, 2007 12:26 AM
Island Accord
Dec 9, 2006 09:30 AM
kimh
Oct 30, 2006 07:11 PM
ckebottle
Oct 26, 2006 04:00 AM
emaxxman
Feb 21, 2006 09:15 PM
