Tire Fit Question
Old Jan 1, 2011 | 09:32 PM
Roadmister's Avatar
Default Tire Fit Question
For my daughters 96 Accord LX, It has been a good car, now ready for some tires. It calls for 185 x 15,
I have near new set of Michilin P215/65 R15 sitting in my shed.
Will they fit?
Old Jan 2, 2011 | 03:58 AM
honDUHchick's Avatar
i dont believe they will fit. they will fit the diameter of the rim, but i believe they are too wide
Old Jan 2, 2011 | 01:27 PM
There's a number missing - the aspect ratio.
I think it calls for 185/65 R15
Your 215/65 R15 tires will be 30mm (more than an inch) wider, and 39mm larger in overall diameter. You might be able to mount them on the rims, but they will probably rub against something in the wheel wells.
Old Jan 2, 2011 | 04:43 PM
Roadmister's Avatar
Thanks for the feed back.
John
Old Feb 25, 2011 | 11:05 AM
wayneii's Avatar
Default Rim Help
i have a 2008 honda accord sedan with some some 20x8.5 rims. i was told that i needed some spacers for a tight fit. would anyone know what size spacers i should get?
Old Feb 25, 2011 | 11:05 PM
Supernaut's Avatar
you may want to start your own thread for this but...you should test fit the wheel/tire on the front and the back for clearance. Also, if you go with a 245/35r-20 you should be good to go for overall fitment/clearance.
98accordman
Oct 24, 2010 10:34 PM
timrivs
Oct 5, 2010 12:25 AM
timrivs
Oct 3, 2010 09:53 AM
abelh7
May 1, 2006 02:28 AM
projectaccord96
Mar 6, 2006 08:54 PM
