torque converter problems
Old Feb 18, 2007 | 01:58 AM
Vishnu
Default torque converter problems
I got my car back from a garage today (94 accord wagon ex non vtec i-4)), I had the engine replaced with a used one. The old engine had 325 000 and blew its second water pump under 75000. I figured it would be just as wise to replace the motor for 1100$. Anyway, when I got on the highway I noticed quite quickly that the overdrive isnt engaging (the torque converter isnt locking up). Anybody have any clues as to what might cause this. The only thing I can really say is that the engine does run alot cooler then the old one (the heat coming out of the vents is not much above 20C/70F). Could it be something to do with the thermostat, and the computer not thinking its warm enough?
Any help would be welcome
Cheers[/align]
Old Feb 18, 2007 | 01:34 PM
wietgr's Avatar
Default RE: torque converter problems
If this problem just started right after you got the engine replaced by the garage I would take it back to them. They may have done something during the engine replacement to cause this.
Old Feb 18, 2007 | 01:36 PM
YeuEmMaiMai's Avatar
We are going to give you the same reply as you got on H-T
if your t-stat is stuck open, your car will not engage the TQ converter. You need to make sure that your car is reaching proper operating temp. It is common for t-stats to be stuck in an engine that has sat around unused for a while........
and note to self.........next time my water pump fails, replace engine [:P]
Rhoderman
May 30, 2007 03:54 PM
poser_pilot6
Apr 5, 2007 02:41 AM
sssexy70
Feb 3, 2007 03:50 PM
huzzsaba
Dec 6, 2006 09:41 PM
absolutalchemy
Oct 16, 2006 02:29 AM
