torque questions
Old Jun 6, 2010 | 10:33 PM
EXV6NIGHTHAWK's Avatar
Default torque questions
Ok guys, these are the tools I plan to use to install my spark plugs. How much torque should I add, for the spark plug tool swivel?
Old Jun 6, 2010 | 10:59 PM
deserthonda's Avatar
do not waste you time torquing the plugs,, i have installed probable thousands of plugs and never used a torque wrench......put a bit of anti seize on the threads, use a hand ratchet ,once they are snug just go about 1/8 turn more and that;s it
Old Jun 6, 2010 | 11:08 PM
But but but, I have a torque wrench, so I would like to use it. Thanks anyway DH.
Old Jun 7, 2010 | 12:23 AM
but but but ...ok... :-)......if you insist ,, torque spec is 13 ft lb
Old Jun 7, 2010 | 01:10 AM
Talking Hello Tool Man
|Hey My Friend...I liked your answer the bestest....Desert
|Hey and NightHawk...better get your torque tool torqu checked, bet it
never has been done since it was new...
Attached Thumbnails torque questions-thumb_obama%2520gave%2520me%2520change.jpg
Old Jun 7, 2010 | 04:05 PM
Thanks a lot guys. What I wanted to know is how much should I add for the spark plug tool. I guess it's not that critical. I'm going with 15 ftlbs.
Old Mar 9, 2013 | 08:14 PM
hemantrhtk's Avatar
I have just put 6 spark plugs ( Ngk laser iridium izfr6k11 ) pre gaped at 0.044.
I have suspicion that spark plug is hitting piston . Is that possible ? I torued them to 18-20 ftlbs.
Please watch the video.
I use 5w20 max life high mileage volvoline synthetic blend oil.
Is it possible I just should shift to 5w30 and this voice will be normal?
Today temperature outside was 50 degree degree F. Is it possible the viscosity if oil I am using is not enough for the power new spark plugs are giving ?
If oil viscosity increase is the solution, what grade I should use 10w40 is good ?
Old Mar 9, 2013 | 08:38 PM
Dr. Drivability's Avatar
screw it, just blast'm with an impact wrench...that'll make sure their nice and tight
Old Mar 9, 2013 | 08:43 PM
shipo's Avatar
While I cannot speculate what the issue is, it's a pretty safe bet that changing the oil viscosity won't help, and whatever you do, don't use 10W-40, the 10W part is way too thick for cold starting your engine. I'm thinking 5W-30 (or better still 0W-30) would be as "thick" as you should ever go for your engine.
len1967
Oct 3, 2006 03:03 PM
MALSR
Sep 26, 2006 08:58 PM
thunder_x
Aug 18, 2006 02:48 AM
Triblade
Mar 16, 2006 11:13 AM
ranst20
May 3, 2005 01:40 AM
