tranny fluid
Old Mar 30, 2007 | 08:12 PM
YJ94
Default tranny fluid
Were is the transmission fluid fill hole on a 2004 accord v6 auto?
Old Mar 30, 2007 | 08:59 PM
deserthonda's Avatar
Default RE: tranny fluid
on top of the tranny , slightly toward the left rear , there is a 17 mm plug,,you will need a 17 mm socket, long extension and a rachet ,, at times those plugs are real tight , remove the plug and put 3 qts of Honda ATF-Z1 fluid
Old Apr 2, 2007 | 07:35 PM
YJ94
Is it a Blue plug?
Old Apr 2, 2007 | 07:54 PM
all the ones i have seen are the same color as the tranny .. a few have had a bit of yellow on it .. does this blue plug look like it is a 17 mm bolt ?? like i said you will need a 17 mm socket to remove it ,,, is it all blue ??
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
nyaccodguy
Mar 17, 2015 06:38 PM
Green_Accord
Apr 13, 2009 08:27 AM
YJ94
Feb 26, 2006 12:33 AM
