tranny fluid change
Old Jun 8, 2008 | 02:59 PM
ziwang55's Avatar
Default tranny fluid change
what oil should i use on my 03 accord i4 tranny it hit 43000 miles and i assume that i need an tranny fluish. any recommended oil for hard driving?
Old Jun 8, 2008 | 04:02 PM
nafango2's Avatar
Default RE: tranny fluid change
assuming its an automatic, you should use honda OEM ATF Z1, dont use anything else. just drain it and fill it. If your overdue, drain it and fill it twice, but go for a drive in between changes.
Old Jun 9, 2008 | 01:59 AM
ziwang55's Avatar
so i cant use amsoil or anything of that type
Old Jun 9, 2008 | 09:39 AM
00AccordLX5spd's Avatar
Registered User
For an automatic, I would probably stick with Honda fluid.
Old Jun 9, 2008 | 10:15 AM
drummer1279's Avatar
amsoil is a good substitute, also the castrol import multi vehicle
Old Jun 9, 2008 | 01:35 PM
finch13's Avatar
I would stick with ATF-Z1 also, knowing Honda auto's lol. Or the GM stuff i the Honda makes the tranny grind more.
Old Jun 24, 2008 | 10:39 PM
ziwang55's Avatar
what do u mean hondas autos is there a bad story about them not using stock tranny oil?
Old Jun 25, 2008 | 08:17 AM
6th-gen (98-02) auto trannys are delicate. Not sure that applies to yours - completely different tranny.
Old Jun 25, 2008 | 03:39 PM
ziwang55's Avatar
interesting....i guess i just need more opinions
Old Jun 25, 2008 | 04:17 PM
brayner's Avatar
no you don't, just get the Honda fluid
