Tranny fluid wont cool. cheked hoses..all seems fine..need help
Old Jul 10, 2009 | 11:35 PM
mike87
Default Tranny fluid wont cool. cheked hoses..all seems fine..need help
SORRY FOR THE DOUBLE POST!!
NOw my problem is as follow, like about 2 weeks ago my tranny has been kicking gears in and out. then i found out that the tranny runs a hose to the radiator to keep oil cool and thick.. lets say i wake up early morning and let the car heat up for a bit. once i put it in drive the car wont move. Now if i start the car, put the gear in drive and start moving it col the car works fine. Not until the engine warms up then the gears dont change. he engine just revs up and does not move foward.
My question is this, did my tranny totally mess up or is there just some kind of problem with a hose cooling the transmission fluid? or is the problem much more severe....
Old Jul 11, 2009 | 07:18 AM
Unlikely to be an overheating problem.
Any recent work on this car?
Have you checked transmission fluid level? If fluid is old, suggest draining and replacing w/ Honda ATF.
Does the D4 light blink? Even if not, check the trans control unit for codes. See following link for instructions: http://www.dhost.info/accordinfo/howto/cel.html
Old Jul 13, 2009 | 10:16 AM
mike87
well actually i had sent the car for a tranny oil change along with the filter. but that was like a month ago. Nothing recent. I checked the engine compartment this weekend and i found a hose which all twisted up and pinched right under the radiator. Took the whole thing out and replaced the entire hose.Also the car used to heat up really FAST and that's when the tranny started to act up. But now that i changed the hose out all seems well so far. Something is also wrong with my speedometer, im doing 45 down a street then all of a sudden the little stick kicks to 80 and then goes back down to 0. Then im there wondering what speed im going. When this happens, if i bring my car to a complete stop if i try to accelerate again the gear wont kick in..Its as if i had put the car in neutral. that when i hated red lights!!..I think now that i changed the hose all of these problems are gone for now.. Gears change fine, no heating up. One problem though, when i took out the radiator i hit on of the aluminum pipes for the a/c and i think all the freon gas leaked. I dont know where exaclty, but can someone tell me how i can figure this out.
this car is a 97' honda accord special edition.
vet67coupe
Aug 8, 2013 11:18 PM
mr_courteous
Apr 7, 2011 10:02 PM
EXV6NIGHTHAWK
Oct 9, 2010 10:35 PM
PJ_STYLES_95AccordEx
Nov 13, 2007 06:18 PM
HondaLawgik
Apr 22, 2006 01:05 PM
