Tranny Problem
Ok, My auto tranny is starting to get annoying. Like every 1/3 dead stops when my car goes to switch into 2nd gear it will slip into neutral for about a second. It's really starting to annoy me and worries me it may cause someone to hit me from behind if i cant accelerate fast enough because of the delay. I had my oil changed and the guy also changed my tranny fluid by using a machine that's like a vacuum to suck out the bad fluid. Didn't seem to help. Any idea why My car is doing this?
ORIGINAL: Vipers4Life
I checked my warrenty booklet and it doesn't say anything about a 100k tranny warrenty.
LOL thanks man. But do you really think i should bring it back now? or should I let the tranny die some more. Right now its just the minor misshift into second. Ill drive it for a while and then see what happens. But do you think they would replace it with the same tranny or do they have a new tranny they put in?
Bring it in now. They would replace it with a rebuilt tranny that is the same type and add an external filter. The new tranny will come with a new warranty, so if it dies in a couple years, you get a fresh one.
It kills Honda AT transmissions. Was it doing it before the flush?
