Trans problem 94 accord manual. Help appreciated
Old Apr 29, 2012 | 01:47 PM
chithunder55's Avatar
Default Trans problem 94 accord manual. Help appreciated
I have a 94 Accord 5 speed and heres whats its doing. I need to diagnose what it is. I thought it was the timing belt and had that replaced but its doing the same thing. Basically when I shift to the next gear, it runs at a real high RPM for a few seconds before the gear kicks in. Its like theres no power to get it going and its trying to catch up. Could this possibly be the clutch? The clutch is only about 5 years old so im thinking its the trans. Thanks alot...
Old Apr 29, 2012 | 02:27 PM
Its hard to tell from the way you described it, but if the clutch is fully engaged and the RPMs rise like that I am guessing the clutch is slipping. Go to a really steep hill and try starting from a stop.
Old Apr 29, 2012 | 02:39 PM
crispin's Avatar
def sounds like a slipping clutch
5 speed transmission cannot slip , either the gear works or it does not work.
it is not like an auto transmission
Old Apr 29, 2012 | 08:04 PM
Robert 1991's Avatar
Sounds like its time to do the clutch, pressure plate and throwout bearing. Be check tolerances on the flywheel and resurface as needed. Do you smell burnt clutch when it does this? Does it slip at cruising speed? I.e. higher rpm at say 50-60mph?
kscott817
Apr 19, 2012 09:25 PM
jpla010
Jan 9, 2012 06:37 PM
TheCosmikshame
Oct 13, 2009 06:59 AM
bwhillzy
Aug 28, 2008 11:48 PM
richny
May 26, 2008 02:28 PM
