Transmission
Old Jul 9, 2010 | 11:24 AM
erheventer's Avatar
Default Transmission
I have a 2006 Honda Accord SE with a manual transmission and I just bought it. I have noticed that after I shift into 2nd and hit the gas pedal sometimes the car will give a slight choppy feeling. Kind of like the feeling you get when your in to high of a gear and your going slow. It only happens sometimes and is very faint and other than that the car runs and shifts smooth. Is this just how the car runs?
Old Jul 10, 2010 | 12:06 AM
kris_loehr's Avatar
I don’t know if you are describing clutch chatter or wheel hop. Taking off in too high of a gear such as forth would be clutch chatter which is similar in concept to a warped brake rotor. With clutch chatter you have a warped or grazed flywheel.
MessAround
Aug 13, 2011 09:45 AM
