transmission
Old Mar 13, 2011 | 10:20 AM
dbty59's Avatar
Default transmission
I guess I posted my question in a wrong area. So, here's the copy of my today's "complain". Please, help with advice.
"Hello, guys. I'm new here. Here's the problem: When I start driving I put transmission into drive D and car starts slow as if I put it manually into a 3d gear. Letter D is too green bright. While I'm standing I try to put handle into P, R, N, D1 and so on. It shifts, but option D continues to be bright green and stays with any other buttons, like when I switch to Parking it goes to Parking but stays on D too. On interstate it does not shift so I go with 3 to 4 thousand RPM. After numerous stops and switching ignition on and off it may return to normal. Pleas help. "
Old Mar 13, 2011 | 11:19 AM
What year and that. Sounds like you have a DTC for the transmission. Depending on year, make, model and maybe a few other things...geting the codes can vary.
Old Mar 13, 2011 | 01:41 PM
dbty59's Avatar
My Honda Accord was made in 1993, I'm sure it is LX. Mileage is 212521.
Old Mar 13, 2011 | 01:54 PM
Ok, there should be a two pin blue connector on the right/pass side to get the codes. Look in the DIY section for exactly where and how to get them. Then post up the codes.
Old Mar 13, 2011 | 02:42 PM
dbty59's Avatar
Thank you very much.
MessAround
Aug 13, 2011 09:45 AM
