Transmission Fluid Change help.
Old Jul 31, 2009 | 09:25 AM
edial's Avatar
Default Transmission Fluid Change help.
I have an honda accord 1999 lx usa model automatic transmision, 2.3 vtec and i wanna change the transmission fluid but here when i live there is no honda premium fluid. what you recomend me others fluid? and is there a oil filter on transmision and if is any is there a problem if i change the fluid without replacing the fluid filter? And something else, when i add fluid i must se the level of the fluid with engine on or off???? I wanna change the fluid because i added dexton 3 and later the transmision donjt change silencly the gears but it change with force especially the first gear. Thank you.
Old Jul 31, 2009 | 01:09 PM
deserthonda's Avatar
if dealer is too far , order fluid online,,, you need 3 qts for just a drain and refill of Honda ATF-Z1. cost is about $ 7+ per qt .....no filter need to be replaced unless someone added an inline filter ..
Old Aug 3, 2009 | 07:35 AM
You asked about checking the fluid level...
Honda wants you to check the fluid with the engine/tranny completely warmed up, but TURNED OFF. Most other (non-Honda) cars are checked with the engine idling.
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
logannz
Mar 30, 2013 05:20 AM
93Accord2.2
Jan 20, 2012 01:02 PM
62maxx
Nov 21, 2006 12:04 PM
