Transmission Fluid help
Old May 14, 2011 | 05:43 PM
Accord Owner's Avatar
Default Transmission Fluid help
I have a 2005 Honda Accord LX SE Coupe, Automatic.
I went to Honda and they have a ATF DW-1 Genuine oil for $7.97 (1 quart). They said I need 3 quarts. Also they said I need 2 crushers, top and bottom which is about $2 each.
Should I buy this or buy Generic from another store?
Also, there is a oil change shop that will change it for me for $20 if I bring my own parts.
Any suggestions?
Old May 14, 2011 | 06:09 PM
Use the Honda stuff. Honda transmissions are temperamental with their fluid.
You will have to call around to see what a place would charge to do that.
Old May 14, 2011 | 06:39 PM
Get the Honda ATF DW-1. I used this on my 2009 Accord and my nephew's 1995 Accord. Both cars shifted very smoothly afterward, mixed with the Honda Z-1 that still left in there.
You just need the one crush washer for the drain plug. For the AT transmission for the 4 cylinder, you fill the fluid through the oil filler tube where the dipstick is.
$20 is very reasonable for the labor.
Old May 14, 2011 | 06:45 PM
Also, buy the 3 quarts for the drain and fill. I usually put 2.5 quarts in first, then recheck the fluid left when the car is at normal operating temperature and add if necessary.
Old May 15, 2011 | 12:48 PM
Well it would be about $25 to buy the ATF 3 bottles and a place that will do it for me is $20.
Old May 15, 2011 | 12:49 PM
If Honda does the parts and labor then its $74.95.
Old May 15, 2011 | 12:50 PM
So 3 quarts is perfect?
Old May 15, 2011 | 12:52 PM
I bought this car at 40K and now I am at 86,650. This will be the first time I am changing transmission fluid. Last year, I checked and the color was not black but not is is black. If I change it this week, will I be ok with no damage? I am not even sure when the last owner changed the oil.
Old May 15, 2011 | 12:57 PM
Well if you are not sure about if it was changed, you can do one drain and fill. Then about a week or two later do a second drain and fill.
Old May 15, 2011 | 01:09 PM
What do you mean? What is one drain? I thought you drain all oil?
