Transmission Fluid help
Old May 15, 2011 | 01:28 PM
The transmission holds about 9 quarts, but only drains 3. The other 6 quarts remain in the torque converter. So when you change your fluid, you only replace 33%. Once you drive, you mix the remaining with the new stuff.
As poorman said, if the fluid looked bad after that , you can drain and refill again. The 3 quarts you drain would be 1 qt new and 2 quarts old. When you refill, the transmission fluid would be 56% new fluid.
Old May 15, 2011 | 01:29 PM
Changing the fluid is called by some "a drain and fill". The trans holds somewhere around 8~9 quarts. Changing/draining the fluid you only get ~3 out. So there is still "some" amount of old fluid left-torque converter, ect. So by "mixing" in fresh, running for some time then doing another drain and fill you get more "fresh" fluid in it.
This job is really easy, remove drain bolt, fluid drains out, re-install drain bolt (with or without new washer-starting a debate), fill trans. Start car, move thru gears, check fluid level, make sure it is correct.....done.
EDIT: I see PA posted as I was typing slow and once again a much better job of explaining......
Old May 15, 2011 | 07:15 PM
Tek310's Avatar
just a added question. is there a filter that needs to be replaced?
Old May 15, 2011 | 09:20 PM
EXV6NIGHTHAWK's Avatar
The 4 cylinder has an in-line filter. The V6 has a filter too, but Honda pretends it doesn't exist.
Old May 15, 2011 | 09:22 PM
Tek310's Avatar
does need to be replaced? i am looking to drain and fill my tranny on my f22b1 and surely it needs to be replpaced with 189,000 miles
Old May 15, 2011 | 09:43 PM
Only 2003+ models have an external filter. Your car has no servicable filter.
Old May 18, 2011 | 01:23 PM
  #17
Accord Owner's Avatar
So there is no way to drain all 9?
So draining 3 and adding 3 is a normal process?
Old May 18, 2011 | 04:36 PM
  #18
The only way to get all the fluid out would be to take the transmission out and take it apart. I don't think you want to do that. Yes, draining 3 quarts, and refilling is the normal way. Depends what the first 3 quarts you drain out looks like, and how much metal is stuck to the drain plug magnet, to know if you need to do it again.
Old May 19, 2011 | 09:42 PM
  #19
Originally Posted by honda69
i will prefer the something like minute oil change shop the guys doing wery good job and more and using genuine parts always
Its the Pennzoil 10 minute oil change. They are very fast in doing it. Not sure how good though.
They said they would do Transmission oil that I bring from Honda so I went to Honda to do this an they charged me $74.86 with exterior car wash and inspections. Is this a rip-off?
Old May 19, 2011 | 09:44 PM
  #20
Honda did this for me and now the oil is light brown from when it was black. Is this normal?
