transmission leaking..
Old Oct 23, 2008 | 11:01 PM
xpieceofcralpx's Avatar
Almost A Senior Member
Default transmission leaking..
i have a slow leak of transmission fluid..causes? concerns? how can i fix this..
Old Oct 24, 2008 | 07:06 AM
Default RE: transmission leaking..
Thats pretty vague... Where does it leak from?
Axle seals?
Shifter?
Input shaft (drips out the bottom of bellhousing)?
Loose drain plug?
Old Oct 24, 2008 | 02:04 PM
uhm, from the bottom of the car , underneath the transmission i guess? cuz i got my oil changed, and when they lifted the car, they showed me the leak, but didnt know if something is cracked or not..
Old Oct 24, 2008 | 04:51 PM
drummer1279's Avatar
could be bad trans cooling lines, could be a seal leak, the drain plug could be stripped or the washer bad, etc...
Old Oct 25, 2008 | 01:08 PM
ok thanks, i shall check out all of those
Old Oct 25, 2008 | 04:27 PM
finch13's Avatar
Can you possibly get a picture of the leak? A good way to find the leak is to spray the transmission down with degreaser, wipe it off, and look for where the fluid is coming from.
Old Oct 26, 2008 | 01:26 PM
ok cool ; i'll take a pic by 2night..thanks
Old Oct 27, 2008 | 07:11 AM
Fluid will blow all around the bottom as you drive. You have to clean it up in order to see where its really coming from.
Your 5-speed does not have tranny cooler lines, so you dont have to look for those.
Old Oct 29, 2008 | 08:52 PM
well i havn't had the chance to take pics yet, cuz been coming home late from work the past few days, and today i couldnt get a hold of my uncle to borrow his floor jack..
but yeah, its a small leak still..like maybe like a puddle about an inch in diameter is left on the garage floor every morning when i pull out..i know this probably a bad idea, but it has been like 3 months now..at first i thought it was oil, so i didnt pay attention to it till i went to get my oil changed..and back then the puddle was like 5 inches in diameter..it's smaller now, so either the leak is stopping, or i'm just losing all my transmission fluid! well there are no symptoms from the transmission yet..so what should i be worrying about now? my friends say, broken or loose seal..gasket..or whatever..i hope my tranny is not cracked or anything..
Old Oct 30, 2008 | 09:45 AM
um if the puddle is getting smaller and you think its low on fluid put more in, if you run it without fluid you'll destroy the tranny.
