Transmission maintenance
Old Oct 27, 2007 | 08:40 AM
imjrk's Avatar
Default Transmission maintenance
Now that I am pulling the engine/auto trans from my 96 Accord, is there any maintenance issues I should do on the trans while it is laying out in the open? Or, would it just be better to order a trans along with the JDM engine? '96 Accord EX 142k miles. Thanks
Old Oct 27, 2007 | 10:47 AM
sir_nasty's Avatar
Default RE: Transmission maintenance
the only thing it may need is a drain and re-fill with some fresh Honda MTF fluid... As long as the clutch, throw-out bearing and pressure plate are fine there's no need to mess with it.
Old Oct 27, 2007 | 12:07 PM
deserthonda's Avatar
ORIGINAL: sir_nasty
Sir my friend it is an Auto tranny..
you might want to replace the axle seals while tranny is out , shifter shaft seal, frt tranny case seal and torque converter o-ring , other than that, if you got no issues with its operation , just put new ATF-Z1 Honda fluid ..
Old Oct 27, 2007 | 12:37 PM
sir_nasty's Avatar
*ROFL* I'm wide awake today! Missed that one totally.... Got an infant at home that's sick and won't let me sleep. Thanks for the correct answer DH.
Old Dec 23, 2007 | 03:28 PM
honda97valdeez's Avatar
IMJRK, HOW DID THE ENGINE REPLACEMENT GO?
azdrake
Nov 4, 2013 07:03 AM
ndp
Feb 26, 2012 02:38 AM
Reboticon
Aug 24, 2010 06:50 AM
GolfingTiger
Dec 17, 2008 11:28 AM
B0BC0X
Dec 7, 2004 03:04 PM
