Transmission problems (TCM)
Old Oct 28, 2011 | 01:09 AM
Dane0vin's Avatar
Default Transmission problems (TCM)
1990 honda accord coupe ex 284710 miles on it. automatic.
one day while driving the car started shifting wrong. it would stay in higher gears. i drove it like an manual car, starting from D1 going up to D4, till i found another tcu. also the sport light would not turn off. so i checked out the tcm (Transmission control module) aka the brain box. two of the capictors were burnt off. so i went to the junk yard tried out FOUR other TCUs. all four gave the same result which was, they would get the sports light to turn off but i was unable to shift out of park.
what i do now is i use the shift lock release and place the car into neutral. then start the car and drive from there. it will drive normally after that, but i will never put it in park since it might stay in park. Reverse, Neutral and drive all work normally.
i dont think its the tcu but something else stopping me from shifting out of park. please help. thank you for the time.
Old Oct 28, 2011 | 01:17 AM
Dane0vin's Avatar
2.2l. i forgot to add that
and by the way, when the problem first occured there was a noise on the drivers side under the dashboard. if i pushed the brake it would stop. i couldnt figure out what it was. and after taking out the burnt capictors, the shaking noise stopped.
Old Oct 28, 2011 | 01:40 AM
In the common DIY thread on top of the gen tech help forum, there is a link to checking engine codes. It is the same procedure for transmission codes, just count the S light.
Post the code(s) you get on here.
Old Oct 28, 2011 | 06:20 PM
Please check for codes....if there are none, you might look into testing the brake and interlock switches.
shutupbiyaatch
Feb 16, 2016 08:08 PM
Brandon Saunders
Mar 18, 2013 12:25 AM
atlsk8crewboi22
Sep 21, 2009 12:39 AM
FELON
May 31, 2008 07:35 PM
appleman
Sep 27, 2007 11:44 AM
