Transmission rebuild. Do you REALLY need to reinstall a new filter?
Old Feb 5, 2015 | 03:46 PM
M-train's Avatar
Default Transmission rebuild. Do you REALLY need to reinstall a new filter?
I'm rebuilding an automatic transmission from a 2000 Accord 2.3l.
For some reason the master rebuild kit don't come with the filter???
Anyway, I'm going to mount an external filter so is there a point to installing a new filter?
FTR: here is the old filter in the black plastic, and no it can't be gutted.
Attached Thumbnails Transmission rebuild. Do you REALLY need to reinstall a new filter?-honda%2520tear%2520down%2520008_zpsxtqjcvl8.jpg
Old Feb 5, 2015 | 04:42 PM
shipo's Avatar
How many miles on the used filter and what kind of shape was the transmission in when the tranny was torn down?
Old Feb 5, 2015 | 04:46 PM
M-train's Avatar
The 1/2 clutches were TOAST, and the others were pretty bad. 150k miles.
Old Feb 5, 2015 | 04:50 PM
shipo's Avatar
I would definitely replace the filter.
Old Feb 5, 2015 | 04:58 PM
M-train's Avatar
I gotta wonder though, why wasn't a filter included in the MASTER rebuild kit. Is there a kit above master, like maybe the GOD kit?........lol.
Old Feb 5, 2015 | 06:53 PM
woody31's Avatar
Almost A Senior Member
You MUST replace the filter. If your kit did not come with one , it is not a master kit nor is it a genuine honda kit.Save the trouble of doing this 2x,,get a filter,,DO NOT try to clean and reuse the old one,,
Old Feb 5, 2015 | 08:06 PM
M-train's Avatar
Oh, I can guarantee you that the filter cannot simply be cleaned as I cut it apart.
On this filter there is no steel screen that you can clean with a little carb cleaner.
The Honda filter has something that looks like wool fabric inside it, and it WON'T come out.
Also, the kit is listed as a master kit..........check out the link below.
http://www.makcotransmissionparts.com/80006E.html
Old Feb 6, 2015 | 10:34 AM
Turtlehead's Avatar
Change it. They are a blend of fabric, special foam and webbing/backing. Also, ensure that the network of micro hydraulic ports are cleaned out before reassembly. Sometimes it takes a small thread of copper wire to clean them...
Old Feb 6, 2015 | 11:09 AM
Another thing to do, the transmission fluid cooler in the radiator should be flushed before installing the rebuilt transmission.
Old Feb 6, 2015 | 03:46 PM
M-train's Avatar
Thanks. I already did the flushing of the radiator cooler, and the torque convertor.
I picked up the filter this morning, and it was actually the right one.
However they didn't have the right gasket maker [no case gaskets in the kit], so I used "the Right Stuff" which was recommended on another forum.
I had Hondabond ordered, but the place I ordered from botched the order so it won't be in for another 2 weeks so we will see how TRS works out.
