trim around the cassette deck
Old Jun 12, 2014 | 11:24 AM
Kax's Avatar
Kax
Default trim around the cassette deck
I have a 99 accord ex. I'm trying to remove the trim around the cassette deck but it seem hung on something. I took the two screws at the bottom out but it still won't come out. Please help
Old Jun 12, 2014 | 11:52 AM
Your post have been moved to a separate new thread. In the future, please create a new thread for a different topic issue.
Old Jun 12, 2014 | 12:03 PM
There is an additional screw in the back of upper pocket that must be removed, 7 panel clips that hold the trim piece in place. Pry carefully to release the clips.
Honda shop manual has this on page 20-87. Check automanualsource.com for a $22 download manual.
Old Jun 12, 2014 | 12:33 PM
Old Jun 12, 2014 | 03:06 PM
Kax's Avatar
Kax
Thank you for the reply but the kind of cassette deck I have is mounted under the am/fm radio with CD player where the center console storage is
Old Jun 12, 2014 | 03:12 PM
Sounds like the accessory cassette deck. See these instructions if it is the same unit:
http://handa-accessories.com/accord/...cassetteex.pdf
If it is the CD player or changer, then these:
http://handa-accessories.com/accord/accordcd.pdf
http://handa-accessories.com/accord/accordindashex.pdf
Old Jun 12, 2014 | 05:41 PM
Kax's Avatar
Kax
Thanks for the info. It was the accessory unit. I didn't realize I had to pop the tabs in rear of the trim. I'll give it a try and report back.
Old Jun 12, 2014 | 05:47 PM
Kax's Avatar
Kax
Also I'm having a hard time pulling off the cigarette lighter from the wire harness. I lifted the tab with a screw driver and it separated a little but it is still stuck
Old Jun 12, 2014 | 06:05 PM
This connector is tough to release. Try spraying some wd40 on connector to release friction. Patience is req'd.
Old Jun 12, 2014 | 07:04 PM
Kax's Avatar
Kax
Thanks texashonda and redbull been real help.
