Troubleshooting :(
Old Jun 25, 2011 | 02:46 AM
WhiteAccord's Avatar
Default Troubleshooting :(
Hi I have a Honda Accord Ex 1994 its been doing good but today it started having a problem turning on it sounds like its going to start but then doesn't than I try for a couple of times and then it turns on I hear the fuel pump starting up Im wondering if its the Main Relay?? Please help Thnx
Old Jun 25, 2011 | 08:07 AM
If engine starts when you hear the fuel pump and doesn't start otherwise, the Main Fuel Relay (MFR) is likely source of problem.
Turn keyswitch to On, you should hear 2 soft clicks (MFR) from under dash, Check Engine Light (CEL) on, and fuel pump run for 2-3 secs and cut off. CEL should go off w/ fuel pump.
If you don't hear the clicks and no fuel pump run, MFR is highly likely.
Post back your findings for additional help.
Old Jun 25, 2011 | 05:34 PM
Default thnx
hey thanx for the help im going to check it out and ill let you know how it goes
Old Jun 30, 2011 | 12:52 AM
hey well first thanx for the help I changed the MFR and now my car starts everytime once again thanx for the help it fixed my problem
Old Jun 30, 2011 | 12:27 PM
Thanks for posting your fix.
94Honda
Oct 30, 2009 02:14 PM
rplowden
Jan 22, 2008 03:17 PM
BeansBaxter
Dec 10, 2007 08:30 PM
jhowkins
Nov 1, 2007 01:07 AM
rcy
Apr 6, 2007 01:29 PM
