Turn Signal Relay
Old Dec 13, 2006 | 10:08 PM
erickyla
Default Turn Signal Relay
My turn signals stopped working. I checked the fuses and although none looked burnt, I replaced them. To no avail, my turn signals still don't work. I'm thinking it's a relay switch. Anyone have any suggestions? Pictures or a schematic -including a description- would be greatly appreciated. My Accord is a 96, EX, 2 Door.
Old Dec 13, 2006 | 11:20 PM
deserthonda's Avatar
Default RE: Turn Signal Relay
relay is located in the underdash fuse box,, top left .....should have 3 prongs
did you chk the fuses >> # 35, 15 amps in the underhood fuse box , and fuse # 12 7.5 amps in the auxiliary fuse holder ??
Old Dec 13, 2006 | 11:31 PM
erickyla
Thank you. No, I didn't check the #35, 15 amps in the underhood fuse box. I'll check it and see if it needs to be replaced. I did check the other one, though.
TheBanker89
Sep 14, 2013 12:30 PM
PeterFlorida
Feb 26, 2013 09:09 AM
Gangsta101
Feb 10, 2013 01:50 AM
dfeat01
Dec 10, 2007 02:49 PM
kennilope
Mar 5, 2007 07:30 PM
